Best program to add textures to Drawings(such as elevations)
piero1910
I am just wondering if I should use Photoshop or illustrator to put textures to my elevations. Both of them have their pros and cons. I like illustrator because I can manipulate more the lines of the drawings from CAD. Something that I cannot do in photoshop so well. Here is an example of the kind of drawing that I am referring to.
http://www.jeannouvel.com/mobile/projets/548_montpellier/dwf/548_facade_ouest.jpg\\
http://www.jeannouvel.com/mobile/projets/548_montpellier/dwf/548_facade_nord.jpg
http://europaconcorsi.com/projects/112806-Jean-Nouvel-Nouvelle-Com-die-de-Gen-ve/images/1599797
I tried to look for tutorials online but I did not have too much lucky finding them. So I would like to know if you can help with. thanks.
Dec 12, 14 11:44 pm
natematt
You could technically use both with exporting and linking, but that is needless here.
For something like your example you should just create a mask for the texture in Illustrator and place it on a layer behind the line-work.
With that much line-work you should always be finishing from a vector software.
Dec 13, 14 12:45 am  ·
Hike Martirosyan
You can compose everything in PS, than export it to AI, work on lines and vice versa till you finish the work.
Dec 16, 14 4:20 pm  ·
boy in a well
psst....
you can make these without ever leaving autocad....except for whatever pixel manipulation you might want to try on your backgrnd images....
Dec 16, 14 5:30 pm  ·
piero1910
Thanks. That was very helpful.
Jan 13, 15 8:59 pm  ·
