RHINO CLIPPING PLANE PRINT
suwatch
Hello fellow rhino users,
Just wondering if anyone has had the same experience...
Trying to print a view of my model with a clipping plane applied. The preview shows a heavy "cut line" where the clipping plane intersects the model. However, the output does not have the "cut line."
If anyone has a solution to this issue I would be forever grateful!
Dec 2, 14 5:22 pm
lukeggg
I have never had this problem, but I think I may be able to help you with a workaround.
Make a flat surface in the exact same place as your clipping plane, and using the intersect command, find the intersection between that surface and all of the geometry you are trying to clip through. You should be left with a bunch of lines (and possibly points, but just ignore those). Group those lines together and give them a thicker line-weight, then delete the surface you made.
Dec 3, 14 8:17 pm  ·
