Onedrive
rudbeckia
Hi Archinect,
I am work for a small firm and am doing some IT research.
We are looking at Microsoft Onedrive for Business + Team Sites for a server. We have 2 locations in different states and need to have access to the same files all the time.
Does anyone use onedrive? If not what type of server do you use for a small firm in different locations.
Thanks for any suggestions.
Nov 25, 14 10:28 am
get a nas.  we have a qnap.  synology makes some.  i think western digital, hp, and a million other people are developing them.  probably set up a vpn or something to share the files between offices.
i can't imagine not having the hard drives at your place and under your control.
Nov 25, 14 11:28 am  ·
rudbeckia
Thanks. We do not have an IT person...would NAS + a VPN be fairly easy to set up?
Nov 25, 14 11:31 am  ·
it's easy if you know what you're doing.  probably not as easy if you don't.  is there someone that makes sure your firewall is doing the right thing?
Nov 25, 14 11:34 am  ·
3tk
We use it, but more or less as an ftp replacement - file upload and download speeds can vary, which may not be great for sharing larger files.
Nov 25, 14 11:37 am  ·
rudbeckia
yes, we have an IT company we use just not an inhouse person
Is the only benefit to NAS over cloud storage that we have the server onsite?
null pointer
You don't want just a NAS, you want versioning and back up. I run a NAS and google drive the folder....
Nov 25, 14 12:04 pm  ·
get your it company to set it up if you're not comfortable with it.
what you might want to do is have 2 nas devices, one at each location, then have that shared as a drive at the other office.  so you would have a 'springfield' drive and a 'capital city drive,' accessible in both locations, and try to mostly keep the projects common for that city in the drive it belongs in.
the vpn would mean the other city's files are accessible to you in your network, so even if you have an xref in a drawing, it will work fine until your isp craps out.
having it on site means the data is transmitted to your computer over a gigabit router instead of over shitty internet service.  if your isp craps out, which all isp's do, you're out of business until they get it working again.  if you get slow download speeds because your isp sucks, which all isp's do, your ability to do your job suffers.  in a world where net neutrality is something that's discussed as an option rather than being the only option, you don't want to trust your isp to keep your business running.
microsoft onedrive or google or whatever else are for backups.
Nov 25, 14 12:15 pm  ·
rudbeckia
the VPN would rely on internet also correct? so still depending on shitty internet
thanks so much for the tips
part of our problem is we are so small both locations work on all projects....so we all need access to everything
microsoft has come up with something called "team sites" that is designed to share data through the cloud....but not sure if it would be appropriate for an architecture office
Nov 25, 14 1:27 pm  ·
urbanity
check the terms for any third party storage of your work products. make sure that your firm retains full ownership and rights to anything stored with third parties. keep in mind that terms change over the years.
other things to consider are security and privacy.
free, although enticing, may not be the best choice.
Nov 25, 14 2:08 pm  ·
yes rudbeckia, the vpn would depend on the internet
but if things go to crap, you would be able to run files at least one location (if you have 2 nas's, you would be able to run files at both, but only the ones local to that office), thus only half as shitty.  half as shitty means you don't shut down, which can be kind of a big deal sometimes.  also, if things really went to crap, you could physically pick up the drive and plug it in somewhere else.
Nov 25, 14 2:17 pm  ·
rudbeckia
thanks for all the info
good point urbanity on the security and privacy
With the onedrive "Team Sites" thing everything is synced local to your computer...meaning if no internet or things go to crap we have all  in both locations
the computers are a mirror image of the info in the cloud, so everything is local yet stored in cloud so access to everything all the time........but i cant seem to find a firm using it....so im sure there is a reason for that or maybe its just too new
thanks again for the help
Nov 25, 14 2:37 pm  ·
